wobbly wheel on 940 e series (bearing)
blsmustang940e
I need to replace a wheel bearing on my 940 E series and so far have seat and wheel off. HELP! How do I get to it? from inside or outside?
If its the front u can remove the floorboard, then there is an access cover for the axle nut , have to drain the oil from chaincase, if its a rear remove tbar assembly and remove the top access cover to chaincase , u willhave to loosen the drive chain, if u get the nut off take a hammer and knock the axle out, usually the inner bearing is ok unless u had water contamination in the chaincase, u will have to keep the sprocket out against the inner bearing (front only) or the bearing will drop out, then u will end up getting into it a lot deeper for the repair, if the rear bearing drops not a big deal u can easily get to it
Mustang 1996 940 e-series only 1 hydraulic filter?
Hi yall.
I removed the seat and did not see a filter. I might see where it has been deleted.
Can anyone show me a picture of this skid steer filter that I believe should be under the seat?
I recently got this skid steer and have changed all the filters except fuel filter and hydraulic filters. I have not found many threads with mustang 940 pictures of under the seat. I plan to post pictures. Today the camera told me to change batteries when I started to take pictures.
Thanks
I thought I was creating my own post. I accidentally replied here.
Maybe the moderater can delete this post?
