Will Bobcat 763 wheels fit s130 ?
toohp
Does anybody know if wheels off a 763 fit a Bobcat s130 ?? so far looks like the s130 have a deeper inside offset ?? Would the stud pattern be the same ? Cheers
763 might use a wider offset. You can flip them and run the valves in if need be. I know the 763 and the 753 which was the older version of the s130 used the same
The bolt pattern is the same, as you know, the offset may be different. I have seen both narrow and wide style rims on a 763.
From what I remember the narrow wheels on a 763 make it the same width as a 753. I believe they are less common than standard wheels
