Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Wheel fell off 675. shaft came out..hard to fix??
Reply to thread
Message
<blockquote data-quote="RJSStamps" data-source="post: 55176" data-attributes="member: 7242"><p>Some machines have a drain plug, some just drain from a bolt hole. Not sure how much oil yours holds but I imagine there is a bit in there. My tanks are huge! If it were me I'd drain it, maybe even put a drain plug in if there isn't one. Then wash it out good to get any metal out before putting it back together. If your axel is groved it's a good bet the clip broke so it is floating in there in two or more pieces. Get them ALL out or you will have bearings and/or gears failing. Use a magnet if you need to to get the junk out of there.</p></blockquote><p></p>
[QUOTE="RJSStamps, post: 55176, member: 7242"] Some machines have a drain plug, some just drain from a bolt hole. Not sure how much oil yours holds but I imagine there is a bit in there. My tanks are huge! If it were me I'd drain it, maybe even put a drain plug in if there isn't one. Then wash it out good to get any metal out before putting it back together. If your axel is groved it's a good bet the clip broke so it is floating in there in two or more pieces. Get them ALL out or you will have bearings and/or gears failing. Use a magnet if you need to to get the junk out of there. [/QUOTE]
Verification
Post reply
