Bobcat Skidsteer Forums
What bucket for S250
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 58393" data-attributes="member: 7339"><p>S250 normally run a 80". A lot of guys like the low pro due to the design, they can see the cutting edge better. There are a lot of aftermarker companies that make buckets, so you should be able to find a new one in your price range. In reguards to the bolt on cutting edge. I have really come to like them. The cutting edge is the fastest wearing part of a bucket and unless you have the skills to cut the old one off and weld a new one on, it is very expensive to replace the stock cutting edge. Now with low use, it should take you forever t wear it down, but personally I would still get a bolt on.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 58393, member: 7339"] S250 normally run a 80". A lot of guys like the low pro due to the design, they can see the cutting edge better. There are a lot of aftermarker companies that make buckets, so you should be able to find a new one in your price range. In reguards to the bolt on cutting edge. I have really come to like them. The cutting edge is the fastest wearing part of a bucket and unless you have the skills to cut the old one off and weld a new one on, it is very expensive to replace the stock cutting edge. Now with low use, it should take you forever t wear it down, but personally I would still get a bolt on. [/QUOTE]
Verification
Post reply
