Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Weird starter issue
Reply to thread
Message
<blockquote data-quote="Mike10" data-source="post: 46796" data-attributes="member: 5461"><p>The engine to transmission gearbox uses 80W-90 oil. The starter, while protruding in the bell housing is separated from the gearbox portion of the bell housing. </p><p>The chain case gearboxes also use 80W-90 oil. In the early units the oil level was checked at plugs located by your heels when you sit in the loader. In those units the chain case oil was 10W-30. </p><p>In the later units the chain case gearbox is lubricated by chain case oil, which in those units is 80W-90.</p></blockquote><p></p>
[QUOTE="Mike10, post: 46796, member: 5461"] The engine to transmission gearbox uses 80W-90 oil. The starter, while protruding in the bell housing is separated from the gearbox portion of the bell housing. The chain case gearboxes also use 80W-90 oil. In the early units the oil level was checked at plugs located by your heels when you sit in the loader. In those units the chain case oil was 10W-30. In the later units the chain case gearbox is lubricated by chain case oil, which in those units is 80W-90. [/QUOTE]
Verification
Post reply
Weird starter issue
