fredycruger
- Joined
- Apr 24, 2015
- Messages
- 2
just traded this machine for my 94 jeep wrangler . . . . . machine is decent... had leak on one of the fitting at pump Oring was bad but that's been fixed now im just trying to button up all the loose ends . . . .
. . . .some of my problems . . . . exhaust muffler was installed too high and whenever cab was tilted back it would contact muffler and push down on both intake and exhaust manifold leaving bottom studs broken and holding on 3 bolts . . . . because the manifold was loose it wore out mounting "ears" off and bolt would only clamp one side of manifold so ill attempt to weld the aluminum manifold and try to build up missing material than grind everything so ex and intake are same height . . . .
. . . one of the rims is narrower and id like to get new 15 x 8 rim but not sure on backspacing and bolt pattern . . . . . this is the rim I want . . . . http://shop.wheelsexpressonline.com/15x8-6x6-Farm-Ag-steel-wheel-15X8-6X6-WHEEL.htm . . . . next on the list is bucket and latch cams . . . . owner did such a terrible job welding on brackets so I will be getting new weld on pieces and new bucket thinking to get this brackets . . . . http://www.skidsteers.com/gehl-mounting-plate-for-models-4510-4515-4610-4615.html . . . . although its for 4610 loader I believe it will fit better if the bucket has flat back
. . . . they list this weld on hook kit for my machine and that looks like it would be better fit if there's 2 angles on back of the bucket . . .. http://www.skidsteers.com/gehl-mounting-plate.html . . ..
. . .. this is 4610 quick attach look same as 3610 . . .
