Vh4d converted to propane
scott1970
Good morning to all. I just purchased an old Bobcat 610 that has a wisconsin diesel that was converted to propane. Got it back to the house and am now trying to get it to run. Turns over fine but won't fire. Pulled the carb and cleaned it. The vaporizer is what I am concerned about. Zenith 962b is what shows on the name plate. Was able to partially disassemble but can't get the upper and lower halves apart. The adjustment screw at the top cannot be moved at all. Should I just plan on replacing it? Also, can a "regular" pressure regulator be used for just testing to just get fuel into the system just to try to get it running? Any thoughts or guidance would be much appreciated. Thanks. Scott
