Other Brand Skidsteer Forums
Mustang Skidsteer Forum
turning issues, i think is a mustang
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 96614" data-attributes="member: 82"><p>It could be a few things, bad drive motor, bad pump, low oil.</p><p>I'd think the dip stick shouldn't be dry, but normally drive systems share the same reserve tank, so if the oil was too low, both sides wouldn't work.</p><p>You can swap drive motors from side to side and see if the issue moves, then it's a drive motor issue.</p></blockquote><p></p>
[QUOTE="Tazza, post: 96614, member: 82"] It could be a few things, bad drive motor, bad pump, low oil. I'd think the dip stick shouldn't be dry, but normally drive systems share the same reserve tank, so if the oil was too low, both sides wouldn't work. You can swap drive motors from side to side and see if the issue moves, then it's a drive motor issue. [/QUOTE]
Verification
Post reply
