Dan Clarke
- Joined
- Apr 25, 2017
- Messages
- 2
Hi, New guy here. I've owned and maintained my 1987 L555 since 1993. For someone who has experience working on the transmission pumps, I have a question about a repair I made. I had a bad leak and found the pump case bolts had loosened and blown the gasket between the pump case halves out. I was repairing at night for the next days work so my solution, with no replacement gasket available, was to install long lower bolts to act as supports so I could slide the housing apart for access to remove the rest of the gasket and reassemble the pump with sealer only. In 300 hours or so it doesn't leak, but I remember thinking that leaving the gasket out might have made the pump slightly noisier than before. My question is: Does the pump require the gasket thickness to establish some clearance factor that I upset by leaving it out? My service manual doesn't refer to checking end play during re-assembly. Thanks, Dan PS. I tried to form this post in easy to keep track of sentences but this editing software just runs it together into one big paragraph. Is there a way to prevent that?
