Tractor PTO conversion
Ironmule
I have a bobcat T250 and some tractor implements I am going to remove the 3 point hitch and replace with attachment plates to fit my machine. What hydraulic motor do I need to achieve the 540 Rpm with a standard flow hyd. system on my machine. I'm needing the part # and brand for this so that the output shaft will fit the driveshaft of the implement.
Read THIS THREAD.
If your T250 is a standard flow model, it should have 21.2 gpm flow in the auxiliary circuit.
You will want the 7.63 cubic inch motor from Surplus Center. They are currently out of stock, so I would give them a call.
Thanks TriHonu. Very helpful information. I will be calling them soon.
