Traction lock on Bobcat 763
Johnboy
Got problem fixed with not wanting to operate. It turned out to be controlled and works good til today. While operating all of sudden the traction lock will go on. It will show a 15-3 code sometimes but sometimes none . I wiggle the manual brake that has the switch and it will work for a while. Is the traction switch bad about going bad on these units? Need help cause when this locks up when moving it will almost send you out the front. Also the traction light will flash 6 times.
The book's troubleshooting section recommends checking the wiring, connectors, and fuse holders for problems with intermittent traction lock issues. Corrosion creeping into connectors causes a fair amount of problems for signal driven systems on these.
