Okay guys I'm trying to fit-up new tracks on the weekend warrior semi-retired Bobcat 753 and the tracks are shifting laterally in turns and binding on the OUTSIDE of the rear "fenderwell" formed by the chassis just behind the rear tire. Just to clarify, the track somehow shifts laterally and rides out away from the tire tread enough for the inside track edge to catch on the vertical plate along the curved rear "wheel well", then rides along out there about 4 inches while carving a nice sliver of steel off the chassis and then pops back in as you straighten up. Its not pretty, but I've not witnessed it first hand- I'm just going by my sons contorted facial expressions as I pull forward. Set up is all stock w/ the exception of new 2-inch wheel spacers. It is a 1994 753 (Blue "753" Decal) w/ NEW Firestone Duraforce HD 16.5-10 tires @ 50psi. The tracks only extend within the face of the rear wheel well about 3 inches, the rest is set outside with the wheel spacer set up. The tracks were ordered for a 753 and I double checked the track sectional dimesnsions and they match what TracksPlus specs. for 10-inch tire dimensions (Track is 9-inches wide at base where the face of the tire tread bottoms out). Track slack is within spec at about 2.5 inches (Spec 1.5" to 3"). I can tighten another link or two but once you start to get 'em within the spec range it is a pita. I have reservations about putting any more stress on the old 753 axles. Tracks plus only suggestion was going ahead and tighten 'em up a little more. One thing I'm noticing is that when you go to the "short hole" in the link, the track links pivot gets real tight and dont flex well once you get the bolts all tight. Basically the track gets relatively rigid links in it. It looks like the extension of the link (first bolt hole section) is binding up somewhere within the track shoe. I'm wondering if just running it in a straight line will break-in the link pivot points? On the pontential issues with tire fit - You can see day light (~1/4 to 1/2-inch) of clearance between the tire side shouler and the track side pads which would certainly contribute to the lateral shifting. Is it possible the 16.5-10 Firestones HD tires shape just tapers too much at the face of the tread to fit the tracks right? What effect does slightly dropping down the tire pressure have on OTT track fit/performance? If anyone has any ideas or experience with the TracksPlus or other over the tire steel tracks, I could sure use some SSForum wisdom. I'm stumped and it does not look like TracksPlus has a solution. As a last resort, I may be facing the reality of having to pick up another set of wheels and very used tires to see if the tire form factor (wider, flat face at tread shoulder with another brand?) and/or worn tread (increased clearance from the machine wheel well) would help. Thats a big "what if" for the relative cost but if it worked I could recover some of the cost by selling the new Firestone HDs. I'll post a pic if I can size these photos down and upload a few.
