TL6R
jbennett99
2018 with 1600 hours. Started it up and the screen never cycled on was just flickering so I turned it off to try and cycle the screen and the whole machine was dead to the world. Will not turn over starter will not engage. There is power going to the key and the starter. I have checked all the relays and the fuses. The Controller under the back right gray panel was making a slight buzzing sound I disconnected the negative battery cable and it stopped when I reconnected it. Any other things that I can check. I have tried to find the controller part number in the manual 1730143426 but can not seem to locate it. I have also checked the display to make sure it was plugged in everything appears good.
