Tip cab with FEL down?
MNBobcat
Hi Guys, I blew the hydraulic hose that connects to the right (bottom hose connection) lift cylinder on my 763H. I know that it's recommended to lift the FEL up high when tipping the cab. Is that because the cab won't clear without it in that position or is it for easier access? I've never lifted the cab with it down. I won't get a chance to work on it until tomorrow so tonight I'm just looking into what I'm up against. How big of a job is it to replace that hose? I'm guessing it goes from the cylinder directly to the spool valve so it can't be all that long I wouldn't think.
shouldn't have to tip the cab. Should be able to get at it from the side and the engine compartment. A set of crow foot wrenches or angle wrenches make the job easier. You can tip the cab up with the arms down. just easier if working under the cab to have the arms up.
