Timken Bearing CM102949 vs LC102949
joetx
Working on an axle on a Case 1840. The Bearing on it is a CM102949 and I looked for it on the net and being directed to LC102949 Are these the same? What's the difference. Thanks.
I did not look it up but the bearings might be the same just a different number because of a different manf. try reverse look up to see if they cross over back the other way on a different bearing seller. that should pretty much tell you if they are the same ,I think anyway.
