tilt cylinder pin replacement 763
Simple job, prices are different depending on where you are.
The biggest issue is the wear, if the bobtach end has worn badly, you need more than just a new pin and bushing. Many get so bad that you need to weld a new boss on the end or bore the end of the ran rod out to accept an over sized bushing.
How bad is yours?
How bad is yours?
some play when digging...I am a machinist,can the bushing be cold rolled steel ? If so I think I could make the boss or bushing...have not looked at the end of the cylinder yet.
For bushings i always use 4140, this way i can harden them and they last. I don't know if cold rolled steel would be hard enough. If you keep it greased and replace it when it wears i see no problem though.
It sounds like you have all the gear to do the job though. I'd never be able to live without my lathe.
