temp. gauge
redfish1
Can somebody tell me if i can use a automotive temp. gauge on a 98 751 with a kubota engine. mine is not working and i would like to take the bobcat gauge out and put in a aftermarket one. thanks for the info
As long as you use the sending unit that comes with the new gauge it should work fine. If you reuse the old sending unit you may not get a correct reading.
Check the price on the genuine parts too, i found the gague and sender to be very reasonable from the dealer.
If you go the aftermarket route, i too see no problem with it, as long as the sender fits the threads in the thermostat housing.
