7LBSSMALLIE
input welcome
how about red white feeding panels?lets start with 4 connector non potted controllers. any fix other than replacement?
one every one should know. if replace brake solenoid replace relay (cause and effect) relay sticks smokin solenoid, to be tech pull and hold, is different replacing one without the other, will result in tail chasing.how about red white feeding panels?
I never thought much about that, but it makes sense. The relay latches on and the pull coil will stay on, same with fuel shut off solenoidsone every one should know. if replace brake solenoid replace relay (cause and effect) relay sticks smokin solenoid, to be tech pull and hold, is different replacing one without the other, will result in tail chasing.
You mentioned stuck rings in your other post, was that soaking in the engine our out?I never thought much about that, but it makes sense. The relay latches on and the pull coil will stay on, same with fuel shut off solenoids
