chance_pittman92
- Joined
- Jul 13, 2020
- Messages
- 1
2014 T550 has been running fine then got to where if I shut it off it had to sit for a few hours then be primed to start back up. I have replaced fuel pick up tube, fuel line and primer bulb, filter, and o ring on bleed screw. When I prime it up it will turn over but not start and then I check the primer bulb and it isn’t hard anymore and there is air in the lines again. Occasionally when the stars align it will crank and runs excellent but if you shut it off it goes right back to air in lines and not cranking. I can’t find any leaks anywhere. What am I missing? Fuel solenoid?
