bradykirby
- Joined
- Sep 14, 2020
- Messages
- 1
I have a 2015 Bobcat T450 with left reverse drive problems. The left motor seemed to be locking up after 20-30 minutes of use. I have had it in the shop and have been told everything from it has bad bearings on the rear idlers to it needs a new left drive motor. Instead of replacing the drive motor, I had Bobcat open it up and inspect it. They said it looked fine and reinstalled it. They also replaced the rear idlers. When I got the machine back from Bobcat, it ran for 15 minutes then I lost reverse on the left track completely. This time a code popped up for the left reverse drive solenoid D7554. I switched the solenoids around and still had the same error code. I checked the solenoids including the left reverse, and they had 6.5 ohms. Once the machine cools down, I will have reverse again for a little while. Forward works great. Any ideas on where to look next? Thanks in advance!
