t300 hyd motor help
ryane7
i have a t300 2600 hrs i recently purchased seemed in good condition when i got it home i brought it to bobcat to check it out and make sure it was in good condition they found alot of metal in case drain and said i need to change right side drive motor their prices was 5800 for motor so i bought a reman unit and they installed i got machine back ran for great for 15 minutes and right side started acting up the right control began to kick back when engaged. left side operates normal but rightside wont go forward or backward unless left side is going same direction. when rightside is engaged charge pressure drops very quickly from 375 psi to under 100 psi but if both motors are engaged in the same direction pressure goes from 375 psi to 325 psi and then slowly lowers. so i call the shop i got remaned motor from they decided a seal going to brakes was bad and brakes on right motor were locking up. and sent me another motor. i changed out the new motor and machine ran great!!!!!! for 15 minutes and this motor now has the same problems as first reman did. after speaking to bobcat they are now telling me that the left motor is bad and that is causing the right motor to not operate correctly. so i need some help i dont know what to believe
