groskeytree
- Joined
- Jan 29, 2024
- Messages
- 3
Hello there I’m new here, I have a 2006 T300 tracked bobcat. I recently had an issue with a drive motor failing to operate suddenly on the left side of the machine when sitting inside. A few years ago we replaced the drive motor on the left side due to loss of drive power on that side. We cleaned out the case filters, changed the hydraulic filters and put a rebuilt unit on there. It’s been very good with no noticeable issues besides maybe a slight lack of power overall. We did have an algae issue in the fuel tank I pulled the motor and cleaned the tank and replace the sending unit and fuel lines. That was a couple years ago. Now for the last year it seems like the machine is struggling more especially when pushed hard. The hydraulic charge pressure seems a bit low at idle is has about 240-250psi at idle 350-380 at full throttle. The most recent major issue we have had is we were moving some pieces of concrete around the yard and as we were backing up the machine the left side locked up. We could figure out the issue so we let it sit there for about 2 weeks as we had other things going on. We came back this weekend fired up the machine and it started moving around like normal. 10 mins later it locked up again and now is throwing a low charge pressure warning and shutting down the machine at idle. I’m puzzled and would like some help.
