I don't think that small difference will be doing much.
Have you changed your air and fuel filters? Is it blowing smoke? it could be a turbo issue too.
Being a tracked machine i believe it will require more HP to move the tracks than a tyred machine. Just how steep is the hill and how hard are you pushing the sticks forward?
As for starting, its possible your glow plugs are burnt out or the timing circuit is not working either. Jusst how much cranking does it take to start it? The starter is also an option too, does it take a bit to crank it?
I have an S250 with a 3 litre turbo Kubota engine, it was hard to start too, it turned out to be bad connections on the starter. I would crank it with a good battery and it would turn slowly, the bolts on the starter were actually getting hot. I Changed the earthing point to the rear alloy cap of the starter, it now works great, starts easily, no excess heat.
