T250 drive issue
BR2022
I have a 2005 T250 with sjc controls it was working and operating fine and all of the sudden the right track won’t drive. The track itself moves freely. There were no noises from the drive motor or anything unusual prior to this happening. I tried switching from ISO to H pattern to see if it may have been a joystick issue but no luck. It doesn’t even try to move if I motion the joystick control that direction. Just changed hydraulic fluid and filter as well as case drain filter 5 hours before starting to have issues, no debris in case drain everything looks well. Lift/Tilt/left drive works fine. Any ideas?
Internal motor shaft is probably sheared, a clean break will not send any debris into case drain filter.
