So, I worked on my machine to fix a linkage issue...the bolt that attaches from the linkage arm to the bone looking arm on top of the case/motor (I assume) sheared off. Not an easy task to replace. After all was done, I drove/tested machine for about 0.3 miles with no issues. Just prior getting to its parking spot, an alarm came on and shortly after the machine shut it self off. I restarted soon after and everything works. However, about 2 mins later that alarm and hydraulic low pressure light comes on. I checked for codes and I get 05-15 code. Even with the light on, the machine functions correctly but it shuts down shortly after. After further inspection, i noticed that the lines are a bit wet (not too bad) by the male end of what appears to be a connection port of some source; maybe to hook-up a pressure gage? What did I do wrong? How should I proceed?
I appreciate your help with this. I used to fix Coast Guard helicopters many years back, but this one is beyond my present understanding of these machines
Thanks
Thanks
