T190 TRACK IS ABOUT TO COME OFF
thechesters
I HAVE A BOBCAT T190 AND THE LEFT TRACK IS ABOUT TO COME OFF...ITS IN PLACE ON THE REAR TOP SPROCKET. THE INSIDE TOOTH IS OUTSIDE THE PULLY ON THE REAR BOTTOM PULLY AS WELL AS THE FRONT...HOW CAN I GET IT BACK IN PLACE.
remove the side cover and remove the zerk fitting. pry the front idler pulley toward the back of the machine it should move a considerable ways the using a pry bar and being carful pry the track back on to the spocket as some one is in the machine to help move the sprocket think of it as a bike chain how you get the chain partially on the use the crank to get it the rest of the way on.
do not remove the grease fitting!!! It is under extreem high pressure. There is a bleed valve next to the grease fitting. Loosen Bleed valve just enough so that grease comes out. The bleed valve looks just like a grease fitting but it is slightly bigger. Just be careful because the grease in the cylinder in under extreem high pressure
yes exactly sorry about the miss info but it has been a while for me but siuramaxde is correct and be careful dont stand in front of it mine must of had hard gease in it when did it and the grease shot out so hard and hit the wall couldnt imagine what that would do too ones face or eyes
