Hi all have a t190 keyless with codes 32-65, sensor supply voltage out of range. i have clean battery pos and grounds at rear of machine. No lift funtion and drive. need help to find where to check supply voltage. Thanks
Your machine is SJC, I'm thinking. It could be an acuator, usually tilt. Are you also getting a code 4004.Right joystick switches error? The sensor supply wires are the green wires from the controller to the acuators.
