T190 noisy tracks
Octaneforce
Just picked up a 2011 t190. The thing is a total beast and works great (ive used it for a day). However, the tracks are very noisy. Its a metallic chattering noise that matches the frequency of the speed of the tracks. Sounds like a metal tracked machine traveling on concrete. The right side is much worse. Im not sure where to start with this or if its just the nature of these machines.
You can check the very front idler and rear wheels. There is a bearing that can possible go bad in each idler. If you can get the a bit of tension off of the track itself and raise the front of the machine off the ground. You can grab the roller and check for side to side play. And do the same on the rear. Or have someone watch as you drive and look for side to side play.
