t-300 k series no start.
gabem1
Had this machine running and working oparator got out while still at idle got back in pulled the safety bar down pushed track release buttun all lights came on but lift/tilt he turned the machine off then tried to restart nothing no power no lights on any thing on the pannel.I came out and checked the basics battery good 12.7v connections tight clean maxi fuse not blown. I removed the light in front of the start pannel supplied b+ to the red/white wire #1220 if I remember right and now have normal oppartion. Has any one ran across this ,it has to be a simple chafted or broken feed wire but not sure were to start.I don't think the right way to re pair it is running this jumper wire. thanks Gabe
plastic panel on the roof where a/c controll is , bottom screw to the front punched thru the wiring harness and damaged a wire or the screw on the left side of the center dash panel damaged wiring harness , 100 amp fuse above the battery , I think you may have called it the maxi fuse and have already checked that
Thank you for the info I did find the the broken wire red/white facing the machine right side along the lower body .Somebody made a repair and did not use a durseal conector or heat shrink tubeing the wire was green and gave way. I should have lifted the cab at the job site, well at least I repaired a leaking hyd.fitting and installed a side glass I ordered a while ago. Thanks again
