T 190 won't turn
lmill59
I have a 2006 Bobcat. Was working fine a week ago.Went to move it yesterday and it will not turn. The left steering lever doesn't seem to work. Any ideas what could be wrong? Thanks
did you look under the cabine can you make ful stroke without bogging with no movement at all then the drive motor is the suspect possebly the end bearing but then there must be oil coming out of the final drive ore the alu lever on the pump broke
