at idol the right track creeps backwards, but stops at high idol. Is this just a lever adjustment or do I have a bigger problem, and it drives to the left when both levers are pushed forward. In 30 feet its probably 1 foot to the left
may need some neutral adjustment , or it maybe a loose pintle arm bolt ---the travel issue is adjusted with the flat rods between the sunstrand pump and the steering bar
You may need some neutral adjustment , or it maybe a loose pintle arm bolt ---the travel issue is adjusted with the flat rods between the sunstrand pump and the steering bar
