Good morning to all. New here and let me state I am not a mechanic. I decided change the oil etc on my 763 Bobcat yesterday. I have had this since 94 so not the first time. I have never had a problem after changing the fuel filter before. So, when it did not start on the first crank, I tried again. At this point I went through the bleeding process. On the third attempt, the starter engaged then silence. The panel lights work, Key on the fuel gauge and voltage etc shows good. Turn to start (starter does not engage). and fuel gauge drops and voltage goes to about 5 volts. release the key to on and there is a blinking of lights and erratic movement of gauge needles before returning to normal. Sorry for the length, wanted to explain all. Called the dealer (recently sold to larger lco.) and an abrupt fellow says, its the battery. Its not, but I did pull it out and clean the terminals. checked the fuse with a meter and all ok. Hope someone can help. Thanks, Bob
