Bobcat Skidsteer Forums
Stupid stupid stupid 'governor' Bobcat 743
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 15641" data-attributes="member: 82"><p>Thats a good point.</p><p>I was always told that the systems will self bleed and just to keep using it. I was told to avoid letting the oil go over the relief so don't let the rams bottom out. If you do, your cavetation can cause damage.</p><p>Cavetation will damage the system as when you compress oil with bubbles the air compresses and causes the bubble to implode causing basically a jet of high pressure oil that can pit the steel.</p></blockquote><p></p>
[QUOTE="Tazza, post: 15641, member: 82"] Thats a good point. I was always told that the systems will self bleed and just to keep using it. I was told to avoid letting the oil go over the relief so don't let the rams bottom out. If you do, your cavetation can cause damage. Cavetation will damage the system as when you compress oil with bubbles the air compresses and causes the bubble to implode causing basically a jet of high pressure oil that can pit the steel. [/QUOTE]
Verification
Post reply
