Bobcat Skidsteer Forums
Still Having Problems with Aux Hydraulics on 863
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 24470" data-attributes="member: 82"><p>So the coil is stuck? or its simply not pulling against the stem?</p><p>Easy way to check if its the coil is to swap it with the one you know works. Just un-plug it and put the known working one in. If the problem swaps sides the coil is bad. You can even remove the coils from the stems and see if the coil pulling will operate the other stem.</p></blockquote><p></p>
[QUOTE="Tazza, post: 24470, member: 82"] So the coil is stuck? or its simply not pulling against the stem? Easy way to check if its the coil is to swap it with the one you know works. Just un-plug it and put the known working one in. If the problem swaps sides the coil is bad. You can even remove the coils from the stems and see if the coil pulling will operate the other stem. [/QUOTE]
Verification
Post reply
