Bobcat Skidsteer Forums
sticky 753 parking brake
Reply to thread
Message
<blockquote data-quote="bobcat753" data-source="post: 24354" data-attributes="member: 2429"><p>I actually discussed this with my local bobcat dealer. Turns out they come as one piece from the factory with the tube already on. Sounds like they slide the wires through then put the end connector on. Ah well I cut it now, tommrow its going to be welded and fixed for good. One less potential problem in the future. Also make sure you guys check your bushings in the seat bar. Luckily I bought new ones, both were worn out especially the right side ones.</p></blockquote><p></p>
[QUOTE="bobcat753, post: 24354, member: 2429"] I actually discussed this with my local bobcat dealer. Turns out they come as one piece from the factory with the tube already on. Sounds like they slide the wires through then put the end connector on. Ah well I cut it now, tommrow its going to be welded and fixed for good. One less potential problem in the future. Also make sure you guys check your bushings in the seat bar. Luckily I bought new ones, both were worn out especially the right side ones. [/QUOTE]
Verification
Post reply
