s-185What machine?
Sounds like you just need to adjust the neutral. You will need a manual and jack the machine up so the wheels are clear of the ground. Neutral adjustment isn't too hard. Just start from the opposite end to the spring. Get one side so the wheels don't move and the stops are tight then do the other side.s-185
I just did this on my rig and will be posting a few more details in a separate thread. Tazza helped me out with advice some time ago and I wanted to emphasize what he just stated:Sounds like you just need to adjust the neutral. You will need a manual and jack the machine up so the wheels are clear of the ground. Neutral adjustment isn't too hard. Just start from the opposite end to the spring. Get one side so the wheels don't move and the stops are tight then do the other side.
