7LBSSMALLIE
PINTLE LEVERS COMING LOOSE DUE TO WORN OT SWASH PLATE EXTERNAL SHAFT WEAR IE BOLT GROOVE.. I HAVE TRIED OVER THE YEARS TO COME UP WITH A FIX. NOTHING HAS WORKED EXCEPCT NEW SWASH PLATES. SO NOT TO WASTE TIME THESE THINGS HAVE BEEN RULED OUT THEY DONT WORK. LOCTITE 660. WASHERS UNDERNEATH. A CHUNCK OF A HACKSAW BLADE. JB WELD. WELD THE SHAFT.., WHAT WE ARE LOOKING AT HERE IS PULL THE PKG TEAR DOWN STAT, REPLACE PLATES RESEAL. I HAVE TRIED EVERY TRICK I CAN THINK OF TO AVOID THIS., NONE HAS WORKED,. DOES ANYBODY HAVE A FIX,
