Other Brand Skidsteer Forums
Mustang Skidsteer Forum
starting probs
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 88953" data-attributes="member: 82"><p>Any warning lights?</p><p>If the time is the same, i'd lean towards the fuel shut off solenoid. If the solenoid is bad, it could run while the pull coil is on, then die when the hold is to take over.</p><p>Is there an arm that goes to the solenoid? if so, cable tie or wire to hold it in the run position, see if the machine stops after 10 seconds. If it keeps running, the issue is the solenoid or the controls for it.</p></blockquote><p></p>
[QUOTE="Tazza, post: 88953, member: 82"] Any warning lights? If the time is the same, i'd lean towards the fuel shut off solenoid. If the solenoid is bad, it could run while the pull coil is on, then die when the hold is to take over. Is there an arm that goes to the solenoid? if so, cable tie or wire to hold it in the run position, see if the machine stops after 10 seconds. If it keeps running, the issue is the solenoid or the controls for it. [/QUOTE]
Verification
Post reply
starting probs
