SR220 drive motor leaking
agsosr220
I just bought a '11 SR220 with 150 hours. The right side drive motor is leaking. The fluid is running down from where the motor bolts on to the inside wall of the chain case. Machine is running fine except puking fluid into the belly pan. Any ideas?
Depends on what sort of seal setup it has.
Bobcat use a seal on the side of the chain case, not the motor its self. If the case drain filter is blocked, pressure will build up and push past the seal. It's possible you have the same issue.
