Bobcat Skidsteer Forums
Spotty Axle Leak - 773T
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 15752" data-attributes="member: 82"><p>It sounds like the axle seals may have been damaged by the wire, just keep an eye on the oil level. They are pretty easy to replace.</p><p>You didn't over fill the chain case so that won't be a problem, even if you did the axle seals should have kept it inside.</p></blockquote><p></p>
[QUOTE="Tazza, post: 15752, member: 82"] It sounds like the axle seals may have been damaged by the wire, just keep an eye on the oil level. They are pretty easy to replace. You didn't over fill the chain case so that won't be a problem, even if you did the axle seals should have kept it inside. [/QUOTE]
Verification
Post reply
