I don't know , sometimes everything seems to be ok but you know something is wrong ----------------what about them cracks are they in the head , do you think it is just casting marks or do you think it goes deeper , if it concerns you then bring the head to a engine rebuilder or a machine shop that could magnaflux it and have it checked out , you could buy the three cans of magnaflux and do it yourself , but the stuff ain't cheap and if you were only going to use it once it probally would be better to have someone familiar with magnafluxing it to check it ------------ does the engine have to be periodically topped off with water or oil , has it ran hot recently -------- if it is losing coolant and there is a crack then maybe it could be steam you are seeing in the exhaust ---------- you confusing me with “ there was oil on the comp end and not on the turbo comp side “ you should not be seeing any oil , the wiggle test will give you some indication of how the bearing are on the turbo shaft but doesn't really indicate condition of seals , if you are seeing oil on one side the turbo if could not be from the turbo but instead becoming from the engine into the turbo ------------something I just thought about is the gate in the turbo which is hooked by linkage to the diapham , I have seen that gate get stuck with carbon build up and the motor smoke but it also made it run bad -------you said the turbo was changed recently , why was it changed and how long ago , I say this because I have seen where after a turbo failure it took quite a few hours to burn off all the oil that had accumulated in the muffler
