slow lift
dtaube
Looking for suggestions before I take to dealer and get bent over.. machine drives fine but us struggling to lift boom and slow to tilt bucket.. boom is biggest problem.. am leaking fluid somewhere in chain case as it is coming out wheel seals but that is a different hurdle.. need ideas where to start on slow lift
Flow equals speed. Pressure equals power. Probably has a worn gear pump.
mine is was doing this also , I added some hydro fluid and it got better little choppy going up now but way better mines leaking as well try adding fluid or check it anyway
Bad seal behind the drive motor causes low fluid in the hydro
the leakage into chain case is reffered to as carrier seals easy to prove pull chain case plug if oil pours out confirmed carrir seals bad. yes you probally know this. but knowing this also means you have probally run hyd sys dry at least once? pumps like oil. pumps do not like air or no oil. pump now be angry. will show its anger by by turning into shrapnel. it will than show its anger by completely trashing youre hydrostat..... brass meets steel steel wins, hope its not too late.
