Bobcat Skidsteer Forums
Bobcat Compact Track Loaders
sloppy bucket on T190
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 67891" data-attributes="member: 82"><p>The first thing to check is the pivot points. It's common for the lower pins/bushings to wear out causing a lot of play where the bobtach pivots on the arms. Also, where the hydraulic rams join from the arms to the bobtach.</p><p>Even a small amount of wear makes the bucket move a lot.</p></blockquote><p></p>
[QUOTE="Tazza, post: 67891, member: 82"] The first thing to check is the pivot points. It's common for the lower pins/bushings to wear out causing a lot of play where the bobtach pivots on the arms. Also, where the hydraulic rams join from the arms to the bobtach. Even a small amount of wear makes the bucket move a lot. [/QUOTE]
Verification
Post reply
