Skid steer wont move. No power to parking switch.
ian58
I have a 2002 Mustang 2070. When I release the parking switch I get power to the entire tractor but the parking brake will not release. The bucket has full power but whenever i try to move the tractor it dies. I have replaced the parking rocker switch and have jumped the timer using the two orange wires. I have also swapped the relays in the back with no change. I cant find an operators manual or an wiring schematic. if anyone has any ideas i would appreciate it.
Does your machine have a controller in the cab by the fuse panel? Under a cover. We had a 2044 that had a drive motor fill the chain case and apply the parking brake but that was only 1 side. I assume you have checked the fuses? The machine runs but won't move?
There is a controller under. I traced The wires There and they all looked good. I have checked the fuses and tried to jump the timer. The tractor has power to The bucket and the wheels but the parking brake won't release. I was thinking about finding the brake and attaching a separate rocker switch to it but I'm not sure if that will cause issues with the other systems.
On our 2044 the brake solenoid is right under the seat. Just follow the hoses. I would guess your controller is getting bad
