Other Brand Skidsteer Forums
New Holland Skidsteer Forum
side plates ls 180
Reply to thread
Message
<blockquote data-quote="AaronS88" data-source="post: 40531" data-attributes="member: 4431"><p>On a LS180 there is a pipe plug in the chain-case ahead of the side cover plate. The RH and LH cases are separate from each other. It will either be a 3/8" hex or 3/8" square to remove the plug. The oil should be level to the bottom of that hole with the plug removed. They hold somewhere around 2 - 2 1/2 gallons of 80W90 gear oil. Make sure the oil is clean, this oil is common with the reduction drive gearboxes under the seat. There are also drain plugs in the bottom of the chain case front and rear, they may not stand right out as they are usually wore down from the bottom of the machine scraping on the ground over time. These take a 5/16" hex to remove, but usually need to be drilled and removed w/ an extractor and then replaced.</p></blockquote><p></p>
[QUOTE="AaronS88, post: 40531, member: 4431"] On a LS180 there is a pipe plug in the chain-case ahead of the side cover plate. The RH and LH cases are separate from each other. It will either be a 3/8" hex or 3/8" square to remove the plug. The oil should be level to the bottom of that hole with the plug removed. They hold somewhere around 2 - 2 1/2 gallons of 80W90 gear oil. Make sure the oil is clean, this oil is common with the reduction drive gearboxes under the seat. There are also drain plugs in the bottom of the chain case front and rear, they may not stand right out as they are usually wore down from the bottom of the machine scraping on the ground over time. These take a 5/16" hex to remove, but usually need to be drilled and removed w/ an extractor and then replaced. [/QUOTE]
Verification
Post reply
side plates ls 180
