OldMachinist
- Joined
- May 24, 2006
- Messages
- 2,748
I have a 2500 square foot fully insulated shop divided into two rooms with a 12' wide by 10' high roll up insulated door between them. The front room has my machine shop equipment and computer. The larger room has a 15' wide by 12' high door to drive vehicles and equipment in to work on. I heat with a 112,000 BTU add-on wood furnace that has two blowers and outlet ducts one going to each room. It sits in a separate insulated room under a overhang. I built special log rack pallets that I pick up with the Bobcat and move into the addition as needed. This allows me to bring wood to the furnace without opening the main shop door and keeps all the ash and dust out. I only have to load the furnace once or twice a day depending on outside temp and if I'm heating both rooms. I only have running water in the front room and have a small electric back-up heater in there just in case I'm gone and can't feed the furnace. In the summer I run a air conditioner mounted thru a wall in the front room where I spend a lot of my time but it will cool the whole shop if needed.
