I am from India.My machine has done 3500hrs.The Hydrostatic Pump seals and Quad rings had to be replaced as there was a oil leak.Removed the Hyd Oil tank and replaced the seal and quad ring.Removed the neutral plate by loosening the spring. All the parts were put back the oil leak stopped but the machine turns left once the press to operate button is pressed.The neutral setting is lost.Please help.
