Sectional drawing of 753F spool valve set ups.
Phild58
Good evening members, would anyone have a sectional drawing of the valve body of a 753F? I'm trying to work out where the seals sit when assembled. Thank you.
If that machine has the Melroe valve you should search for the "melroe control valve manual". There is a component repair manual for it that walks you through everything you need. Also check https://www.bobcatpartsonline.com/ and look up your model and you should be able to find at least drawings of the parts in the valve. From what I remember some of the valves had subtle differences in where and how you put the seals on/in. Some versions the seals go inside the spool bore in the valve and others you put the seals on the spool first and slide it in the valve.
The Melroe Control Valve manual is available in the manual thread.
