Bobcat Skidsteer Forums
Same problem again, tapers and bolts
Reply to thread
Message
<blockquote data-quote="waggles" data-source="post: 52524" data-attributes="member: 3105"><p>When you remove the bobtach , insert both tapered pins in the arms and measure them with a long straight edge to see if they line up with each other. If they are good then check that the bobtach touched both stops at the same time, and as Tazza said are both rams the same ? one may be different and have a longer stroke that twists the bobtach everytime .</p></blockquote><p></p>
[QUOTE="waggles, post: 52524, member: 3105"] When you remove the bobtach , insert both tapered pins in the arms and measure them with a long straight edge to see if they line up with each other. If they are good then check that the bobtach touched both stops at the same time, and as Tazza said are both rams the same ? one may be different and have a longer stroke that twists the bobtach everytime . [/QUOTE]
Verification
Post reply
