S650 weak lifting power
jimfunk
Hello, I am new to this forum and am looking for some help with a Bobcat S650. We have weak lifting power, bucket curl and dump are strong and we flowed tested and she was good. We ruled out the cylinders and could use some help from here. Any thoughts?
If there is no leakage on the hoses to the cylinders, the pump is good it could be a problem with port reliev valve.It may also be an electric or mechanical problem If the machine is with levers / pedals it may not pull the plunger on the valve to the end and this is the reason. If is equiped with joysticks may need calibration.
